TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Germany
Can I See How Strong Is The Wifi Signal?
I have try to find a answer for my qestion.
When i use my robot outside from my house, the robot disconnect. Now i use a extra WIFI Dongle. But how far i can go?
Gives a script or a option for display the signal strenth?
And my second question is, how i can change the EZB from Clientmode to AP Mode back with the Webserver? I have the Settingsite and i have change this. I have try this 10 times. All times i become display saved.
After reboot, the Clientmode is always back.
I can only reset this setting for press the Resetbutton on the EZB. But for this, i must oben the Cover.
Thanks for your service
Wifi signal is monitored by Microsoft Windows. Use a program like wifi info or look at your wifi network list.
Oh, I also thought that you can see wifi networks and their signal strength if you have a v4.x/2 by telneting into the console. I forget the command, but you can type "help" to see commands.
Germany
Ah ok. When i start te EZB in the AP Mode i see this in the Windows. Its ok for orientation. I was hopeless for a option for the EZB software in the app or desktop mode. Thanks DJ Sures.
I can change after reset to Client mode. No Problems, all works fine.
But the next problem is the Option in the EZB for change the mode Client to AP. How can i change this back without opening my robot and using the Resetbutton? I can change to the Clientmode and i can configure all options. But when i try to go back in AP mode, the EZB gives "save". After reboot, the EZB starts all 10 seconds new and makes reboot again. When i turn Power off and start new, all setings are not accept.
You do not have ezb v4.x/2 upgrade to see the wifi signal via the telnet interface. Otherwise, if you're using Client Mode, some routers will display the signal strength in their admin interface.
I do not understand your last post. However, if you want the additional new features, and faster communication, consider the EZ-B v4/2 Comm Upgrade
I use an AT&T WiFi hotspot on my robots.Allows WiFi with ezb anywhere that there is cellular network. Also Hotspot device can connect 5 devices at the same time. It is the size of a cell phone.
Germany
Thank you for your patience. My English is bad. I know.
I've found all the errors myself. My router does not have this option.
RB550F that is a good idea. I have a repeater now as a hotspot in the garden. The range is gigantic. Thanks
Germany
Last day i have try a wifi repeater for my wlan. I have some questions.
Does it use the same WLAN in the repeater with the same SSID? Or do you use the repeater another SSID?
The EZB works with my wlan complete. But when i go out of range, the ezb dont connect the repeater with the same SSID. So i have all times signal lost.
When iam driving and i lost signal, my robot dont stop. He drive away. I must run out of my house and catch my robot. Is this normal?
When EZ - builder lost the control, they is frozen. Complete out of control. I become a windows error.
And when i start in the normal menu the cam, and when i end the cam, i become a error and ARC. Frozen and closed application.
Different repeaters work differently. Some (most) can be set to use the same SSID, and your device will just connect to whichever one has the strongest signal, and should switch over seamlessly between them. I actually just use a second router with DHCP turned off, and hardwired to my main router as a network extender, and it works well with EZ-B. I had a repeater that also worked well, but it got ruined when my basement flooded.
I have seen some that we not really repeaters but more like internet sharing devices. They had their own SSID, DHCP server with their own IP address range, etc, just like a router, they just got their internet from your main router wirelessly. That would not be a good solution for EZ-B.
