Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Resolved Resolved by ptp!
Can I Use 'Continuous Servo' For A Cooling Fan?
Can anybody suggest how I can power a fan from an EZB and control it using something like 'Continuous Servo'?
Continuous Servo by Synthiam
Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls
There are at least 3 types of Power fans:
  1. 2 wires (+, -)
  2. 3 wires (+, -, TACH)
  3. 4 wires (+, -, TACH, PWM)
A, B types:
For A, B types you can connect a H-bridge https://www.ez-robot.com/Shop/AccessoriesDetails.aspx?prevCat=9&productNumber=14 and you can control the fan with https://synthiam.com/Support/Skills/Movement-Panels/Dual-HBridge-w-PWM?id=16067 control.
it works similar to a continuous servo but is not a continuous servo.
C type: The fan has a embedded micro-controller, and the proper way to drive the fan is to use the PWM pin. Note: Some fan's PWM pin requires a high frequency i.e. 25Khz.  You can try connect the PWM pin to an EZB's digital pin and use the pwm slider: https://synthiam.com/Support/Skills/Pwm/PWM-Slider?id=16047 IF does not work due the frequency (EZB PWM is not 25Khz) you will need an arduino micro-controller  and code some custom firmware to generate the 25Khz frequency.
And one further suggestion is to remove the electronic pcb from a continuous rotation servo and connect it to a regular fan.
that way you use the servo pcb to control the fan speed. And in ARC you’ll just a regular continuous rotation servo control with speed for both directions:)
Both @PTP and @DJ Sures answers assume you want speed control on the fan.  For a simple on off, you just need a transistor (and potentially a voltage regulator or alternate power source depending on whether the fan can run on the same voltage you are providing to your controller).
Ha ha ya and Alan is right on that observation:). The easiest solution is the most elegant
Thanks very much for details of the numerous options. This level of support is amazing!!!!!
Let us know how it works out for you
