Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Portugal
Can Pimoroni Servo 2040 be an EZB?
Can Pimoroni Servo 2040 Be An EZB?
I plan to use a Raspi 4 as an embedded SBC.  From that I want to use four EZBs to control sensors and servos.  Does anyone know how to make a Pimoroni servo 2040 into an EZB?  Is it possible?   Thanks
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
#1   — Edited
We do not have a Pimoroni servo 2040 controller to test with, but we may be able to whip up a firmware for you to try. They are not Arduino compatible, so our existing firmware will not work on their onboard microcontroller. They are python compatible, so the firmware could be altered to work with python. We were hoping you could test the various firmware we build to get it right.
Have you considered using any supported EZBs or servo controllers? As seen here: https://synthiam.com/Support/Hardware/Hardware-Overview
cd26453
do you mean something like this ?
hi
i found this video about the servo board 2040 .
They'll communicate via USB, I believe. The documentation for that board is quite vague. We're having a few challenges sorting it out
