Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
Can The Ezb Use A Ir Blaster Instead Of Direct Connection To
robots like robosapien that use the IR PORT
I guess this might be a question for DJ,
Second idea can EZB receivved a command for a remote on robosapien or other IR control robots and make a code to control it,like a learning remote does.
This way DJ you dont have to make seperate IR codes for each robot
USB-UIRT module has this built-in
