Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Can You Charge Wireless Camera While It Is On?
Hello,
I was wondering if I can charge the wireless camera while it is in use? Or when it is in use, does it cutoff the charging, even if it is plugged in?
If it does charge while it is on, you can extend the battery in the camera by getting a cheap usb flash charger and keeping it attached to the camera while it is on.
#17
Cost is 1/3 more some less depend on a cheap design,size is another problem ,look at the super tiny charger that comes with the camera.
ANY charger will work as long as it puts out 5 volts and you can use a 20 amp charger if you have one,unit and battery only draws what it needs.
ON cell phone charger is perfect for the design small and compact ,low cost and 1000 ma output mostly every one made.
:)thank you all.yes that answered my question.
