Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
Resolved Resolved by ptp!
Can Someone Spot The Error In My Code?
Can someone tell me why I am getting this error? I must be going code blind or I found a bug. ARC version 2020.05.18.00
Error on line 4: Missing ) in Expression
$HumanSaid = "birds can fly"
$Sentence = $HumanSaid
$xCount = 0
repeatwhile(contains($Sentence, " "))
$xStrLength = Length($Sentence)
$xIndex1 = IndexOf($Sentence, " ")
$Sentence = SubString($Sentence,$xIndex1 + 1,($xStrLength - ($xIndex1 + 1)))
$xCount = $xCount + 1
endrepeatwhile
$WordCount = $xCount
Script by Synthiam
#1   — Edited
ASFAIK there is no error, it's an EZ-Script bug this code works:
$HumanSaid = "The quick brown fox, jumps over the @## lazy dog !!!"
$xCount = 0
$contains=contains($Sentence, " ")
repeatwhile($contains)
endrepeatwhile
print("Total words: " + $wordCount)
Quote:
Start
Total Words: 11 Done (00:00:00.0219259)
You should move away from EZ-Script to Javascript or Python.
Javascript version:
function countWords(str) {
  var matches = str.match(/[\w\d\’\'-]+/gi);
  return matches ? matches.length : 0;
text = "The quick brown fox, jumps over the @## lazy dog !!!"
print("Total words: " + countWords(text) );
Quote:
Start
Total words: 9 Done (00:00:00.0128812)
Python version:
import string
words = sum([i.strip(string.punctuation).isalpha() for i in text.split()])
print ("Total words: " +  str(words))
Quote:
Start
Total words : 9 Done (00:00:00.0184166)
Thank you PTP, I am starting to use JavaScript. But when I can't find what I want to do it is so easy to fall back to EZ-Script. Have to start from scratch as most of my scripts just vanished when I installed ARC and I can't find any backups and I know I have made lots.
by the way what does ASFAIK mean?
AFAIK  =As Far As I Know
ASFAIK = PTP's version of AFAIK (All rights reserved):)
Thanks again PTP
Are you just trying to count the number of words? Use the split() function and get the array length
@ DJ, Yup that is what I am doing. Thank you DJ
