The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Portugal
Can we use the ARC mobile app outside our home network?
Can We Use The ARC Mobile App Outside Our Home Network?
Hi, I am trying to use the ARC mobile app to control my EZ-B v4 using  4G network on my android phone using port forwarding. Have been trying but with no success. Is this possible? Any help would be great. Thx
Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile.
Not overthinking, misunderstanding.
I assumed the EZ-B/Robot is behind a 3G/4G network, before i used an Android phone to share the internet (hotspot) currently i use this:
The facts above post 5 are correct if you try to configure a 3G/4G device as NAT server.
There are a few threads discussing the common scenario (cable internet providers), check one of my posts: post #4 https://synthiam.com/Community/Questions/Connect-To-My-Cloud-And-Use-The-Virtual-Machine-4902
I don't know why I assumed the most complicated scenario ...
I would wait for a good post from thetechguru:)
PTP's link above is exactly what I was going to provide as method 1.  It is probably the simplest, but you do need a dynamic DNS service, or some kind of device on your network that can send you your IP address periodically (your IP is likely to change any time your router reboots, and with some providers more often).  It is fairly easy to script in windows or Linux (on a Pi) to send you your current IP address by email or text periodically so you don't need dynamic DNS.
Method 2 would still require needing to know your IP address or a dynamic dns host name, but would be a bit more secure.  Set up OpenVPN on a Raspberry PI on your network.  You can then connect to it from your phone, and your phone appears to be on your network for all intents and purposes.  This is a bit more secure (if configured correctly) because you only have one port forwarded, and OpenVPN is very secure.
Method 3 would be to have a PC on your network running and use TeamViewer (or similar) remote software.  The advantages are you don't need to know your IP address because the connection is controlled through the service provider, and you get the full power of ARC rather than the more limited mobile interface.  Disadvantage is that you are seeing the entire ARC screen on your phone, and even though you can zoom in and pan around, it might be overkill for your purposes.
Method 4 would be to use the web server or custom web server in ARC to create a custom remote interface.  Not much benefit to that over the other methods though (and in fact, the standard web server does not even have a password, so probably not a great solution).
This weekend I'll provide more details on each of these with some links and maybe even some diagrams if I get inspired:)
As usual, my weekend had more things to do than time to do them.  I'll try and update more details on these solutions one evening this week.
Portugal
Thanks Alan, i am using team builder and it is ok.
That is actually my preferred method despite the density of data on the screen.
