Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Do you have access to the router to see the DHCP leases that have been handed out? You should be able to find the IP address that was issued to your EZ-B V4 there.
Reboot your pc and your ezb (cycle the power) and try again....
Germany
I've rebooted everything, but nothing changed. I also cannot hear a ping response while scanning. My router shows 2 MAC and IP addresses, dunno how to interpret.
Also check the default IP address in ARC and make sure it matches your network. By default it shows 192.168.1.1 and it would search for devices in that subnet and if your router is not configured for that it will never find any devices. My router's default subnet is 192.168.0.1 so I had to change the IP address entry in ARC to reflect that.
Germany
How can I find out the right network IP address? Shown is 192.168.1.1:23 as the default. Okay, the address seems to be correct.
OT: how can I read your answers when they are available? Some alert option, or manual retry required?
go to a command prompt and type IPCONFIG and hit enter. See what your machines IP address is. Ods are that your EZ-B will be on this same range.
if your IP address is 10.10.10.100 your scan range in ARC should be 10.10.10.1 to 10.10.10.254.
