Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
chould the blue led change in green?
The blue LED is AP mode and green is Client mode. So you cannot connect your iPhone to the EZ-B using the mobile app then? Remember this will be AP mode (direct connection from iPhone to EZ-B, no router).
Also I just wanted to confirm, have you run a scan using the connection control in ARC to find the EZ-B?
ok am connected in ap mode on iphone and yes i did a scan
So the EZ-B is okay then. That's good. Can you try and connect your computer to your EZ-B with AP mode now. If that works (and I don't see why it shouldn't) then I recon its a problem with your router. If you can connect you computer to the v4, I'd go back and go through the connection process again from the start to connect via "Client Mode".
i cannot connect to ARC.i can connect app mode. i notest one thing i have to keep the ezb very close to the iphone. yes i think some is wrong with the engenius but only d cohran knows that.
So it is just "Client Mode " you're having trouble with. Okay, well at least we have narrowed the problem down a bit. Maybe David will chime in if he has time, but it might be worth going through and reading your old forum threads again when you had this trouble before, and see if you can figure it out in the mean time. At least you know you haven't got a bad EZ-B anyway.
the engenius is diff for me .i will do more harm then good.
thanks steve g now i know how ap mode works. i think last time was similar problem,server fell out then problem starts. david repair it engenius has alot of settings.
#16
I don't have time to look at it yet.
Do any of your ezbs connect to the network? If so, the issue isn't the engenius. We turned off mac address filtering last time.
I won't be able to connect to see what is going on until tomorrow morning CST. I am away from my house and won't be back until late tonight.
