Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
That's because your script is repeating for ever in a repeat loop.
Read your script, it's doing what you're asking it to do...
  1. run a soundboard
  2. flash an led for ever
That's what you're asking it to do. What do you want to do?
1 say sound file,play motion,flikker led 2 stop all
@nomad ... take lines 2 and 12 out (no repeatuntil).... The script will only run once but it will do what you want...
I can help you but give DJ the credit for this... I don't want any credits at this time....*
RR
ok i give credit it dj
i made a video.
@nomad... your script repeats so the leds won't ever stop... Either remove lines 2 and 12 or add a long sleep command after set(D11,OFF) (after line 11)....
thank you bolt.
