My mimo is installed in the Devices and Printers section, but it won't install as an Extended monitor. I had it working at one time, I thought. But, it just says builtin monitor.
EZMQTT Broker
— Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients.
Which control panel are you in? The Windows 8 screen one or the main one through desktop?
It should appear in Control Panel, All Control Panel Items, Display, Screen Resolution. In there you can change the appearance of the displays etc.
Can you post a screen shot of the control panel page where you think it should be? (Hold windows button & press volume down)
This is a little hard on the W3. I had it stored for months while waiting for the arm parts to be sent. Finally, I made them myself. Not as pretty, but at least they are done.
The final on this is that while it was stored, the battery when completely dead. So, I have to plug it in to the battery on the robot in order to operate the W3. But, because that is what I wanted if for, it is ok.
I will see what I can come up with. i plugged the monitor in my desktop and it came right up. I realized that I needed a Dual Usb cable which I did not have at first. I changed the cable, but no soap. I have the monitor listed in devices and printers, but not under monitors in the device manager.
I am working the device manager and also the Display settings. It only shows the built in monitor.
Thanks!
What is it listed under in Device Manager?
It is listed under Devs and Printers
Thats not device manager.
This is device manager, whats it listed under in here?
Get to this by going to; Desktop Explorer (the icon of the folder by the windows button in the lower left) Control Panel (in the ribbon along the top) Device Manager
yes, I meant to say that it is NOT showing up under Device manager/monitors.
What is it showing up under in device manager? It must be showing up as something. Devs and Printers is not the device manager I am on about though, I mean what is it under in the device manager which I posted a screen shot of? Does it have any error codes?
No errors. It says all of the devices are working.
