Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
Thank You, oldBotBuilder. I tried that program about ten times so far with no results. But, thanks for mentioning it.
  1. close ARC if it is running
  2. Load the registry editor by pressing Windows Key -> R and type REGEDIT and press enter
  3. Navigate the register tree to this folder HKEY_LOCAL_MACHINE\HKEY_CLASSES_ROOT\INSTALLER
  4. Now press CTRL-F to display the find window. Enter ARC.
The GUID for the uninstall information of ARC will be displayed and highlighted in the tree. Delete the tree item.
  1. Reboot your computer
Thank you, my friend for going to all this trouble.
I have seen many who have had the same problem. I tried their solutions without results that worked.
I did exactly that you suggested and after I rebooted and tried to install it told me an older version cannot be removed. sorry :-(
I look forward to your next release.
I installed Windows Installer 5 latest version for windows 7. rebooted my machine and then tried to install the program.
Still Failed.
PleasePleasePlease come out with a new release. Thanks.
#15
For this afternoon's working session, go ahead and get TeamViewer re-installed. You don't need to set it to start on boot-up, so it will only run when you need to let me in and start it so won't slow down the computer.
Talk to you later.
I will do this. I am back home now, so you can call when you wish.
Thanks,
Mel
