Diagnostic Report icon Diagnostic Report — Collects and sends ARC diagnostic reports to Synthiam to help troubleshoot EZ-B and robot connection issues Try it →
Resolved Resolved by EzAng!
Can't connect ARC on my win10 pc to my raspberry as server
Can't Connect ARC On My Win10 Pc To My Raspberry As Server
hi, i can't connect ARC on my win10 pc to my raspberry as server. This error comes up: EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: Forcing decimal separator for numerical values Windows version: Microsoft Windows NT 10.0.18363.0 Screen Resolution: 1366x768 (96x96 dpi) ARC Version: 2020.07.29.00 Attempting connection on 192.168.0.104:23 Comm Err: System.IO.IOException: Unable to write data to the transport connection: An error occurred during the connection attempt as the connected party did not respond properly after a period of time, or an error occurred on the established connection as the connected host could not respond. ---> System.Net.Sockets.SocketException: An error occurred during the connection attempt as the connected party did not respond properly after a period of time, or the established connection failed as the connected host could not answer at System.Net.Sockets.Socket.Receive (Byte [] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read (Byte [] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read (Byte [] buffer, Int32 offset, Int32 size) in EZ_B.EZB.FdnCbVUtAt (Int32, Byte [] cmdData) BbytesToExpect: 1 OR Received: 0 Disconnected I followed all the steps, thanks and greetings.?
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Can you provide more details about your "raspberry as server" ?
Do not select a ton of random skills related to the question. Select only the related skills. I removed them all for you since no skills apply to this question.
Hello thanks for answering and the advice. Sorry if I don't detail too much, I'm new to all of this. I have a raspberry pi 3 B + and I installed EZBpi server version 5. Also i have My win 10 pc with ARC version 2020.07.29 Both are on the same wifi network. ARC detects my raspbarry when I give it scan, but when I give it connect it returns that error. If you need detailed information, Tell me please how to provide it
This is on my win 10 pc
This is from my raspberry
Hi,  on your win 10 pc, first, make sure you have your anti-virus off to connect to Arc.
I always need to do this.
Also check firewalls
EzAng
It was the antivirus the culprit! Now it connects! many thanks! Thank you all!
Thank you very much man, I will take it into account for the next one. I love your youtube channel!!
