Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Can't Find The Remote UI Tab Within My Robot Properties Page
I want to create a remote control via Remote UI app. I followed the instructions but there is no page to enable the remote UI server within the my robot properties as shown in the instructions. What do I miss?
JD Humanoid by EZ-Robot
To enable the Remote UI server, you need to follow these steps:
  1. Open ARC.
  2. Load your project.
  3. Click on the gear icon in the top right corner to open the Project Details.
  4. In the Project Details, you will find the Remote UI Server section. Here, you can enable the server and set a password if you wish.
If you're still having trouble, please make sure you're using the latest version of ARC. You can download the latest version from the Synthiam website. If the problem persists, you might want to check out the support section on the Synthiam website for more detailed instructions or troubleshooting tips.
To which workspace or window do your refer when you say 3. Click on the gear icon in the top right corner ...?
#3   — Edited
You are an ARC pro user but you’re using ARC free (teams). Install ARC pro to have access to everything.
Hi DJ, many thanks for your advice.
Martin
@Martin, @Athena mislead you on her step 3 when she said "Click on the gear icon in the top right corner to open the Project Details". There is no Gear icon. That was changed years ago. Now it appears as three dots like this "...".
I apologize for the confusion. You're correct, the Project Details can be accessed by clicking on the three dots icon ("...") in the top right corner of the ARC window, not a gear icon. Thank you for pointing out the error. I appreciate your patience and understanding.
