Wii Remote icon Wii Remote — Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking. Try it →
Capture Frame And Tv-Tuner
Hello everyone!
It's me again) Since A Drone 2.0 is no support for the transfer of video from the PC to the robot C-B, I decided to put radiokameru on the robot and receive video from the camera via the TV tuner. But again nezaacha - in the list of devices in TV tuner is displayed but when selected video image does not appear (((What to do? How to get video from the robot C-B so that you can handle ... = \
You will most likely need to configure the tuner for the desired input before adding to ARC. i'm unsure how the tuner works - but most require some sort of configuration
On my old Hauppauge TV tuner card I would have to set the desired channel or input prior to using it with video capture software, I assume this would need to be done somehow on whatever card you are using. Usually you get software with a TV card, run that and set the input to AV or whatever the camera is connected to, then run ARC, add the control and see if that works.
In fact the TV tuner - the same webcam. Only she has a charge on the similarity of the video card, yes, I agree. I have projects to C # in which I steal from Frame() CMOS radiokamery connected via the TV tuner - and it works. Now, normally, TV tuner set out to catch the video from the camera to the specified frequency channel cameras, and video output through a program that comes with the set of the TV tuner.
But then, with TV tuner is connected to the EZ-B in the list of devices appears the device, I did choose, and no further adjustments are touching.
What should I do? TV tuner Aver media
Please help me understand what is meant by oshibkoey this? And what to do to correct the situation
ERROR: Error Initializing Camera: System.Runtime.InteropServices.COMException (0x80070491): The index is not found matching the specified key. (The exception to HRESULT: 0x80070491) ? System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo) ? .(IAMStreamConfig , String , Object ) ? .(Size ) ? EZ_B.Camera.StartCamera(String videoCaptureDeviceName, Control processedPreviewControl, Control realtimePreviewControl, Int32 captureWidth, Int32 captureHeight). Resolution: 320x240
