Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Maybe I don't understand... but plug in your servo to your ezb4 and find out. Then centre it with ezb builder then attach your sonar the way to want it to be.... then you're done...
rr
okay thanks
Patrick, if that is a picture of the servo you are asking about, you need a voltage regulator. It is a 6v servo. If you plug it directly into the EZ-B with a Lipo battery or a 6AAA battery pack you will burn it out.
hi alan
i have a voltregulator for the ping sensor.but i use servo's from here.
thanks
