Ez430-Chronos Wrist Watch icon Ez430-Chronos Wrist Watch — Map TI eZ430-Chronos watch accelerometer X/Y tilt to ARC servos for intuitive, Wii-Remote-style control of servo positions. Try it →
Resolved Resolved by Proteus!
Changing The Name Of The Ez Network
Hi Guys.
Atm I have 9 EZ robots for teaching programming to kids. When they all get turned on more or less at once, there is 9 Networks pretty similar in name, this gives some confusion and irritation with both me and my students.
My question is: Is it possible to change the names of the Networks ? and if, how is it done ?
Thanks
Portugal
Hi, you can change the SSID with diferent names like so:
Hope this helps.
Portugal
Don't forget that you must do this for every EZ bord. Regards
If using 9 robots in AP mode in the same room, you should also change the WiFi channel (on the same configuration page) on each one to avoid interference. If they are all on Channel 1 you will have significantly shorter range and may see other symptoms like unexpected disconnects.
Don't forget, the plastic used with ezrobots can be written on with a sharpie. Write the wifi name on the robot.
To wash the sharpie off the robot, use white board cleaner - voila:)
