i dont see a wait command in the cheetscheet for the camera.i wanted for jd to wait before he sees the color red, then do the respons.
— Edited
Audio File Out EZB
— Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips.
Use RoboScratch or Blockly to learn the code that you would need to do that. RoboScratch and Blockly were designed to teach people how to code. They're great tools that I recommend you use to learn how to code.
hi dj
i did try to find it in blockly,but no luck.roboscratch seems not to work here.
Roboscratch and Blockly will work in any country with ARC. There's no reason it won't work there. Use the manual or tutorials or activities or RoboScratch or Blockly to learn to program. The best and closest The Robot Program episode for what you're asking is here: https://synthiam.com/Community/Tutorials/95?courseId=1
I recommend using Blockly or RoboScratch because you don't have to write any code and the commands are there.
the module dont change into roboscratch.
sorry about this i see it now.
jd dont speak in RoboScratch and i dont see a :startloop and goto(startloop)
