Floor Map— Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings.Try it →
Both options are presented in the Six Hexapod Course. The Six Hexapod course is presented to you when ARC is first launched, or accessed by the top of this website by clicking the learn menu option. Here is a direct link to the course for the Six Hexapod: https://synthiam.com/Tutorials/Course/2
just checked bolt.bolt are clockwise.
if i change the right side counter clock wise,i set D1to 130 degree
D16 TO 130
D13 TO 130
in Auto Position window.is there anything els to look out for.
To assemble your six, there are 2 methods.
Use the ARC 3d automated instructions: https://synthiam.com/Tutorials/Lesson/27?courseId=2
Use the web instructions in the Six tutorial under learn menu item: https://synthiam.com/Tutorials/Lesson/62?courseId=2
dj thanks
just checked bolt.bolt are clockwise. if i change the right side counter clock wise,i set D1to 130 degree D16 TO 130 D13 TO 130 in Auto Position window.is there anything els to look out for.
If you modify the position of servos, there are a few places which will require updated positioning with Six Hexapod deafult project
All Auto Position frames
Camera servos for tracking
Mobile Interface for servo Slide Trackbar
seems better to leave it thisway like it is.
