Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
Cognitive Emotion Getting Error Message
Getting this error message while using cognitive emotion ..is this usual?
Checking... System.InvalidOperationException: An invalid request URI was provided. The request URI must either be an absolute URI or BaseAddress must be set. at System.Net.Http.HttpClient.PrepareRequestMessage(HttpRequestMessage request) at System.Net.Http.HttpClient.SendAsync(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationToken cancellationToken) at Microsoft.ProjectOxford.Common.ServiceClient.d__222.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Common.ServiceClient.d__202.Checking... System.InvalidOperationException: An invalid request URI was provided. The request URI must either be an absolute URI or BaseAddress must be set. at System.Net.Http.HttpClient.PrepareRequestMessage(HttpRequestMessage request) at System.Net.Http.HttpClient.SendAsync(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationToken cancellationToken) at Microsoft.ProjectOxford.Common.ServiceClient.d__222.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Common.ServiceClient.d__202.
You have an invalid enpoint url ? You should use the endpoint url displayed in your azure account.
Have used endpoint code too..
Can you post your endpoint?
Have gone with Endpoint URL but its showing error message like this..
System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 40.112.254.71:443 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context) at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Common.ServiceClient.<SendAsync>d__222.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Common.ServiceClient.<PostAsync>d__202.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Emotion.EmotionServiceClient.<RecognizeAsync>d__6.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Microsoft.ProjectOxford.Emotion.EmotionServiceClient.<RecognizeAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult() at Microsoft_Cognitive_Vision.FormMain.<Camera_OnNewFrame>d__14.MoveNext() in C:\My Documents\SVN\Developer - Windows\ARC skill plugins\Microsoft Cognitive Emotion\Microsoft Cognitive Vision\FormMain.cs:line 166
Key2 is not the endpoint.
Look to the picture, you have Endpoint, Key1, Key2:
Questions:
  1. Please post your endpoint url:
  2. Can you reach internet from your desktop/ARC ?
Sorry to insist. I believe you are using the wrong endpoint url, go to your microsoft api account and use the endpoint url listed there.
Attention:
  1. API keys are assigned per (Region) endpoint's url.
  2. Some services are not available outside the selected geo location.
