Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
@nomad... DJ hasn't been able to finish object recognition yet, so you can't delete right now.... You have to start a new project or delete the camera control and then add it back to your project...
rr
ah and have you any idea why servo does not track?
What are you trying to track? Colour, face, motion or object? You need both x and y servos in order to track up and down and side to side... You only have the x servo set in your picture above.. Also try increasing the min and max values... Do not use muti servos here... just x servo and the y servo beside it...
rr
the face tracking works.color not. but it seems that its only for things that move forwart?
Colour has to be red with a lot of light on the object (you can change the colour, but red is the default colour).... The x and y servos are supposed to be the servos in a pan and tilt set up... Like your JD's head... Set the servo for x (the servo that makes JD move his head side to side) then set the y servo (the servo that makes JD nod up and down)...
increasing values ,you mean not 1 degree to 180 but excample 80 to 100 i use red ball
What servo is the 80 to 100 for? That is only 20 degs of travel, that's not very much... Try 30 min and 150 max... Make sure those servos can move from 30 to 150 freely... I mean make sure that those values won't make the servo smoke or bind on anything...
