Sound Servo (PC Mic) icon Sound Servo (PC Mic) — Maps PC microphone volume to servo positions - control multiple servos (e.g., robotic mouth) with scalar, min/max and invert options. Try it →
Com Error When Download Configuration For EZ-B V3
Trying to get up and running on my EZ-B v3. Couldn't get a servo to work so I took a step back and tried to make sure things were talking. Added Debug control. Looked good. Added EZ-B v3 Configuration control and tried to download configuration. Debug results:
2020/09/25 19:10:09 -04:00 - Attempting connection on COM4
2020/09/25 19:10:19 -04:00 - Connected to COM4 at 9600
2020/09/25 19:10:19 -04:00 - Reports EZB v3 OS
2020/09/25 19:10:19 -04:00 - Firmware 'EZ-B v3 Native Firmware' on 'EZ-Robot EZ-B v3' supports the following capabilities:
 - ADC with 8 Bit resolution
 - Read/Write Digital I/O Ports
 - I2C Master
 - PWM Duty on digital ports
 - PWM servos on digital ports
 - PWM servos on digital ports can release their position
 - servo speed for PWM servos on digital ports
 - Transmit Uart TX on all digital ports
 - Ultrasonic Ping distance sensor support
 - Native Bluetooth Connectivity from ARC
2020/09/25 19:10:30 -04:00 - Comm Err: The operation has timed out.
2020/09/25 19:10:30 -04:00 - BbytesToExpect: 1
2020/09/25 19:10:30 -04:00 - Received:
2020/09/25 19:10:30 -04:00 - Disconnected
How do I get this thing ticking?
EZ-B V3 by EZ-Robot
EZ-B v3 works with Synthiam ARC via Bluetooth COM port to control servos, sensors, scripts and robot skills.
Bluetooth
reviewing the logs from your installation of ARC, it appears you may not have enough power correctly provided to the ezb v3. I would consult the ezrobot manuals or datasheet for the product from their website. What power supply are you providing the ezb v3?
I am using the battery pack/holder that came with the kit.
