ADC Graph icon ADC Graph — Historical ADC graph and numeric readout (0-255) for 0-3.3/5V inputs; configurable board/port, sample interval, color, and pause for ezb controllers. Try it →
Com Ports in Connection Control
Com Ports In Connection Control
This is a two part. One part may be best answered by EZ Robot but hoping someone may have insight. The second is probably Synthiam's.
I'm trying to connect several EZB's through their camera ports via USB-to-TTL Serial Cable directly to a laptop USB ports.
First, When I was ready to connect the first EZB to ARC, Com 3 showed up in ARC's connection control and after picking it the connection worked.  Yah!
However a couple days later I restarted the robot and the laptop and now it won't connect to ARC through Com 3. After resetting the EZB back into AP mode I was able to connect through ARC over WIFI. Then I tried Client Mode WIFI through my home network and was also able to connected to ARC. Then after another EZB reset and I again set the unit up like last week to connect over USB. Com 3 was there in the connection control but ARC couldn't connect through it. No go. Nada. Nothing.
Second, When I connect tried to add a second EZB to my laptop using the USB-to-TTL Serial Cable a second Com port does not show up in ARC's connection control. This may sound like a dumb question but shouldn't a second com port show up and be used for a second EZB attached to the laptop through USB?
When I first plugged in each of the USB-to-TTL Serial Cables into the laptops USB ports, Win 10 told me they saw them and set each up and was ready to use.
Any ideas would be welcome.
EZ-B V4 Info by Synthiam
Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control.
#1   — Edited
It worked and now it doesn’t:) . Check your settings - baud rate, port, wiring, common gnd, etc
You can connect as many ezb’s as you want. Up to 255 I think is the max for ARC.
oh, and if you connect the usb after ARC has loaded, you’ll need to press the refresh button next to the port selection on the connection control. That refreshes the list of com ports.
Thanks DJ. So each new ezb connected by USB to the computer will connect through a new and different com port?
That’s right. And windows will remember the com port for each adapter for next reboot. Just make sure you save the project so the ports and baud configuration are all saved.
what baud rate are you using? 25600 or 230400 is fine. Anything higher might produce errors
Twitter
Did you install tho FTDI VCP drivers in windows?
Hey thanks for the info!
@Nink, I wasn't aware I had to install drivers. I thought Win 10 did that in the background when the adaptor cable was first plugged into the laptop's USB port. I was first trying to connect over USB to my onboard Rock Pi X but got frustrated thinking it was the SBC. I switched over to my Win 10 laptop that has ARC set up on it and got the same results. I had set up the SBC according to all the advice Synthiam gives along with the driver pack offered here. I guess looking into missing drivers is a good place to start along with Dj's advice given.
@DJ, I had tried several baud rates (setting them both in the EZB firmware and in the ARC Connection Control. When it was first working I picked the highest rate (9xxxxxxxxxx or something like that). Then when I couldn't connect anymore I changed it down to 230400 with no results. Maybe I'll trim it down a little more.
Thanks again for the tips.
Found the reason I connected ok one day between EZB and the laptop over USB and not the next. Broken wire between the USB of the laptop and the camera port on the EZB. Wonky pre crimped jumpers. Ugh.
Next I'll get the other EZB's connected through USB to the laptop.
BTW, I found the FTDI drivers, downloaded them and installed into the win 10 laptop. The Driver website said Win 10 would do this automatically when the cable is plugged into a USB port. I don't know if they were working or not so I reinstalled anyway.
Thanks for the help.
Right click on the start menu and select device manager to view your list of devices. A yellow icon will be beside devices that are missing drivers.
If the icon isn’t there, no need to install drivers for it because it’s working. Installing drivers might be incorrect or older or viruses / you never know:)
