I searched the forum but didn't see an answer to my question. Can EZ 3 and EZ 4 boards be used together in a project if both are updated with the latest software?
Thanks,
- Scott
Target Overlay
— Overlay translucent PNG targets onto a camera stream with loadable templates, attach/detach control, preview and status for visual alignment.
Thanks,
Yes, currently ARC supports both, and you can combine them in a single project. Keep in mind when using multiple boards that some commands can only be sent to "Board 0", most importantly, the movement panel, but some others as well, so plan carefully which board will be used for which.
There will likely be a time when DJ stops providing updates that support the V3 board, so read the release notes carefully, and keep a backup of the last working version whenever you update.
Thanks Alan :-)
Dude, you should have searched your own forum threads... You asked the same identical question 2 months ago... Combining different ez boards
