Pandorabots icon Pandorabots — Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots Try it →
Combining Older And Newer Boards?
So can older and newer boards (ez-bv4) be used in the same project? The physical configuration of ports is different and I don't seem to be able to get anything in the older board to activate (the newer one works fine).
Thanks,
Daniel
The older board works on Bluetooth, so your laptop/PC needs a Bluetooth dongle if Bluetooth is not built in. You also need to follow the steps to pair and sync with the Bluetooth board. Did you do that?
Whoops! I'll check. I bet it was still set to network. Daniel
