Comm Err: The Operation Has Timed Out
my ez-b was working for 3 days, now when i try i get this...
Attempting connection on COM3 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected
OK. I did all you said. And still no dice
#26
Ya, I can't think of any other things to test or check so it is time for a replacement board.
OK. Thanks everyone for the help. Is there any way to order just the Ez-B Chip and Bluetooth chip?
#28
Just go to the Support selection at the top of the page.
What part of the support section? Its just about getting started and so on.
#30
Go to "EZ-B Diagnostics" scroll down on the right side until you see "Contact Us" in blue.
#31
Did you find any solution? I didn't.
