Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Communication Between Ez-B And Dension Wirc?
Hi,
I just bought one of these:
https://www.wirc.dension.com/wirc
I'm not an electronics or RC person, so here is my question:
Is there a way to get the EZ-B and WiRC device to communicate directly, via a cable? What sort of extended functionality could be expected?
It should be possible to do in in software as well, by passing outputs from the WiRC DLL to various inputs in the EZ-Robot DLL. But it would be nice if there was a simple way to bridge the hardware side. Then you could combine this with the sofware link to potentially use the WiRC to transmit EZ-B data.
David.
