Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
#57
@alid,
You said this is your office. When using other devices, does it actually ask for SSID, Username, and Password? If so, it is using WPA2 Enterprise, which is not supported by the EZ-B. If other devices connect with just SSID and Password, it should work, but it needs to be 802.11n or 802.11g backwards compatible (n is better, either will work).
If all your other devices are 802.11ac and the WiFi is set for 802.11ac only, it won't work. Note also: many 802.11ac routers have different SSIDs for the g/n network than for the ac network, so make sure you are using the right SSID.
MAC filtering is set in the WiFi router or AP, so you would need administrative access to check that.
Thailand
#58
Thanks Alan
About other devices, only SSID and pass is enough to connect. I gonna check with net engineer in my company and I'll right back here.
#59
Acer Video Player EZ-Builder Foxit PhantomPDF Intel(R) Dynamic Platform and Thermal Framework Intel(R) Processor Graphics Intel(R) Sideband Fabric Device Driver LavasoftTcpService McAfee LiveSafe - Internet Security McAfee WebAdvisor Microsoft Office Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319 Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 Minecraft Movavi Screen Capture 5 Qualcomm Atheros WLAN and Bluetooth Client Installation Program Realtek Ethernet Controller Driver Realtek High Definition Audio Driver
Ping 192.168.1.1 replied Success took 1
Name: Local Area Connection* 4 Description: Microsoft Hosted Network Virtual Adapter Status: Down Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500
Name: Local Area Connection* 3 Description: Microsoft Wi-Fi Direct Virtual Adapter Status: Down Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500
Name: Wi-Fi Description: Qualcomm Atheros AR956x Wireless Network Adapter Status: Up Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500 DHCP Server: 192.168.1.1
Win32_NetworkAdapter
Realtek PCIe GBE Family Controller AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000000] Realtek PCIe GBE Family Controller ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Realtek PCIe GBE Family Controller DeviceID = 0 GUID = {58260752-504A-4C3D-BC57-5B2C5BC83682} Index = 0 Installed = True InterfaceIndex = 3 MACAddress = 2C:60:0C:2F:BF:33 Manufacturer = Realtek MaxNumberControlled = 0 Name = Realtek PCIe GBE Family Controller NetConnectionID = Ethernet NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_09331025&REV_0C\4&37B3C6A9&0&00E2 PowerManagementSupported = False ProductName = Realtek PCIe GBE Family Controller ServiceName = RTL8168 Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft Kernel Debug Network Adapter Availability = 3 Caption = [00000001] Microsoft Kernel Debug Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Kernel Debug Network Adapter DeviceID = 1 Index = 1 Installed = True InterfaceIndex = 2 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Kernel Debug Network Adapter PhysicalAdapter = False PNPDeviceID = ROOT\KDNIC\0000 PowerManagementSupported = False ProductName = Microsoft Kernel Debug Network Adapter ServiceName = kdnic SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Bluetooth Device (Personal Area Network) Availability = 3 Caption = [00000003] Bluetooth Device (Personal Area Network) CreationClassName = Win32_NetworkAdapter Description = Bluetooth Device (Personal Area Network) DeviceID = 3 Index = 3 Installed = True InterfaceIndex = 8 MaxNumberControlled = 0 Name = Bluetooth Device (Personal Area Network) PhysicalAdapter = False PowerManagementSupported = False ProductName = Bluetooth Device (Personal Area Network) SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft ISATAP Adapter AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000004] Microsoft ISATAP Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 4 Index = 4 Installed = True InterfaceIndex = 10 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\ISATAP_0 PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft 6to4 Adapter Availability = 3 Caption = [00000005] Microsoft 6to4 Adapter CreationClassName = Win32_NetworkAdapter Description = Microsoft 6to4 Adapter DeviceID = 5 Index = 5 Installed = True InterfaceIndex = 4 MaxNumberControlled = 0 Name = Microsoft 6to4 Adapter PhysicalAdapter = False PowerManagementSupported = False ProductName = Microsoft 6to4 Adapter SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Qualcomm Atheros AR956x Wireless Network Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000006] Qualcomm Atheros AR956x Wireless Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Qualcomm Atheros AR956x Wireless Network Adapter DeviceID = 6 GUID = Index = 6 Installed = True InterfaceIndex = 5 MACAddress = AC:B5:7D:3D:0F:E1 Manufacturer = Qualcomm Atheros Communications Inc. MaxNumberControlled = 0 Name = Qualcomm Atheros AR956x Wireless Network Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_168C&DEV_0036&SUBSYS_064211AD&REV_01\4&137E63BE&0&00E1 PowerManagementSupported = False ProductName = Qualcomm Atheros AR956x Wireless Network Adapter ServiceName = athr Speed = 54000000 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft Wi-Fi Direct Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000007] Microsoft Wi-Fi Direct Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 7 Index = 7 Installed = True InterfaceIndex = 6 MACAddress = 1E:B5:7D:3D:0F:E1 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&2BDDF27D&0&01 PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft Hosted Network Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000008] Microsoft Hosted Network Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Hosted Network Virtual Adapter DeviceID = 8 Index = 8 Installed = True InterfaceIndex = 9 MACAddress = 5E:B5:7D:3D:0F:E1 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Hosted Network Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_SAP\5&2BDDF27D&0&02 PowerManagementSupported = False ProductName = Microsoft Hosted Network Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Teredo Tunneling Pseudo-Interface AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000009] Microsoft Teredo Tunneling Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Teredo Tunneling Adapter DeviceID = 9 Index = 9 Installed = True InterfaceIndex = 11 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Teredo Tunneling Pseudo-Interface PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\TEREDO_TUNNEL_DEVICE PowerManagementSupported = False ProductName = Microsoft Teredo Tunneling Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Microsoft ISATAP Adapter Availability = 3 Caption = [00000010] Microsoft ISATAP Adapter CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 10 Index = 10 Installed = True InterfaceIndex = 12 MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter SystemCreationClassName = Win32_ComputerSystem SystemName = AVIVS_LAPTOP TimeOfLastReset = 20150616152351.486049-240
Win32_NetworkAdapterConfiguration
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0 Caption = [00000000] Realtek PCIe GBE Family Controller Description = Realtek PCIe GBE Family Controller DHCPEnabled = True Index = 0 InterfaceIndex = 3 IPEnabled = False MACAddress = 2C:60:0C:2F:BF:33 ServiceName = RTL8168 SettingID = {58260752-504A-4C3D-BC57-5B2C5BC83682}
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1 Caption = [00000001] Microsoft Kernel Debug Network Adapter Description = Microsoft Kernel Debug Network Adapter DHCPEnabled = True Index = 1 InterfaceIndex = 2 IPEnabled = False ServiceName = kdnic SettingID = {8718928D-CBEB-45EA-A621-800A9249001D}
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=3 Caption = [00000003] Bluetooth Device (Personal Area Network) Description = Bluetooth Device (Personal Area Network) DHCPEnabled = True Index = 3 InterfaceIndex = 8 IPEnabled = False ServiceName = BthPan SettingID = {6915F8C1-5AF7-420C-A5AD-2B269A73A4C6}
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=4 Caption = [00000004] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 4 InterfaceIndex = 10 IPEnabled = False ServiceName = tunnel SettingID = {48893A9B-5AF3-48BF-B50E-9C4E8889BC96}
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=5 Caption = [00000005] Microsoft 6to4 Adapter Description = Microsoft 6to4 Adapter DHCPEnabled = False Index = 5 InterfaceIndex = 4 IPEnabled = False ServiceName = tunnel SettingID =
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=6 Caption = [00000006] Qualcomm Atheros AR956x Wireless Network Adapter DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.1.1 Description = Qualcomm Atheros AR956x Wireless Network Adapter DHCPEnabled = True DHCPLeaseExpires = 20150617170425.000000-240 DHCPLeaseObtained = 20150616170425.000000-240 DHCPServer = 192.168.1.1 DNSDomain = home DNSDomainSuffixSearchOrder = home DNSEnabledForWINSResolution = False DNSHostName = Avivs_Laptop DNSServerSearchOrder = 192.168.1.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 Index = 6 InterfaceIndex = 5 IPAddress = 192.168.1.5 fe80::99f0:c90e:a450:f108 IPConnectionMetric = 25 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 MACAddress = AC:B5:7D:3D:0F:E1 ServiceName = athr SettingID = TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=7 Caption = [00000007] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 7 InterfaceIndex = 6 IPEnabled = False MACAddress = 1E:B5:7D:3D:0F:E1 ServiceName = vwifimp SettingID =
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8 Caption = [00000008] Microsoft Hosted Network Virtual Adapter Description = Microsoft Hosted Network Virtual Adapter DHCPEnabled = True Index = 8 InterfaceIndex = 9 IPEnabled = False MACAddress = 5E:B5:7D:3D:0F:E1 ServiceName = vwifimp SettingID = {2E35C092-264B-4761-A93E-EEB6256E36E5}
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=9 Caption = [00000009] Microsoft Teredo Tunneling Adapter Description = Microsoft Teredo Tunneling Adapter DHCPEnabled = False Index = 9 InterfaceIndex = 11 IPEnabled = False ServiceName = tunnel SettingID =
\AVIVS_LAPTOP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=10 Caption = [00000010] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 10 InterfaceIndex = 12 IPEnabled = False ServiceName = tunnel SettingID =
AVIVS_LAPTOP AdminPasswordStatus = 3 AutomaticManagedPagefile = True AutomaticResetBootOption = True AutomaticResetCapability = True BootROMSupported = True BootupState = Normal boot Caption = AVIVS_LAPTOP ChassisBootupState = 3 CreationClassName = Win32_ComputerSystem CurrentTimeZone = -240 DaylightInEffect = True Description = AT/AT COMPATIBLE DNSHostName = Avivs_Laptop Domain = WORKGROUP DomainRole = 0 EnableDaylightSavingsTime = True FrontPanelResetStatus = 3 HypervisorPresent = False InfraredSupported = False KeyboardPasswordStatus = 3 Manufacturer = Acer Model = Aspire ES1-111M Name = AVIVS_LAPTOP NetworkServerModeEnabled = True NumberOfLogicalProcessors = 2 NumberOfProcessors = 1 OEMStringArray = String1 for Original Equipment Manufacturer String2 for Original Equipment Manufacturer String3 for Original Equipment Manufacturer String4 for Original Equipment Manufacturer String5 for Original Equipment Manufacturer PartOfDomain = False PauseAfterReset = -1 PCSystemType = 2 PCSystemTypeEx = 2 PowerOnPasswordStatus = 3 PowerState = 0 PowerSupplyState = 3 ResetCapability = 1 ResetCount = -1 ResetLimit = -1 Roles = LM_Workstation LM_Server NT Potential_Browser Master_Browser Status = OK SystemType = x64-based PC ThermalState = 3 TotalPhysicalMemory = 2023440384 WakeUpType = 6 Workgroup = WORKGROUP
#60
Hello @Foxybros
Looks like your computer has a Qualcomm Atheros AR956x Wireless Network Adapter which should work fine.
Try disabling your McAfee anti-virus software.
#62
ICMP Response
Testing to see if the network is the same ip subnet as the ez-b. Ping replied TimedOut took 0
Wifi Adapters
Name: Local Area Connection* 2 Description: Microsoft Wi-Fi Direct Virtual Adapter Status: Down Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500
Name: Local Area Connection* 3 Description: Microsoft Hosted Network Virtual Adapter Status: Down Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500
Name: Wireless Network Connection Description: Intel(R) Centrino(R) Wireless-N 6150 Status: Up Receive Only: False DHCP: True Auto Private Addressing Active: False Auto Private Addressing Enabled: True MTU: 1500 DHCP Server: 192.168.2.1
Network Adapters
Realtek PCIe GBE Family Controller AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000000] Realtek PCIe GBE Family Controller ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Realtek PCIe GBE Family Controller DeviceID = 0 GUID = {764E3BE0-A159-46CD-A99A-A73E43D42D63} Index = 0 Installed = True InterfaceIndex = 6 MACAddress = 08:2E:5F:8B:27:12 Manufacturer = Realtek MaxNumberControlled = 0 Name = Realtek PCIe GBE Family Controller NetConnectionID = Local Area Connection NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_165B103C&REV_06\4&225BCE71&0&00E0 PowerManagementSupported = False ProductName = Realtek PCIe GBE Family Controller ServiceName = rt640x64 Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft Kernel Debug Network Adapter Availability = 3 Caption = [00000001] Microsoft Kernel Debug Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Kernel Debug Network Adapter DeviceID = 1 Index = 1 Installed = True InterfaceIndex = 9 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Kernel Debug Network Adapter PhysicalAdapter = False PNPDeviceID = ROOT\KDNIC\0000 PowerManagementSupported = False ProductName = Microsoft Kernel Debug Network Adapter ServiceName = kdnic SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Intel(R) Centrino(R) Wireless-N 6150 AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Intel(R) Centrino(R) Wireless-N 6150 Driver ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Intel(R) Centrino(R) Wireless-N 6150 Driver DeviceID = 2 GUID = Index = 2 Installed = True InterfaceIndex = 10 MACAddress = 40:25:C2:CB:C2:5C Manufacturer = Intel Corporation MaxNumberControlled = 0 Name = Intel(R) Centrino(R) Wireless-N 6150 NetConnectionID = Wireless Network Connection NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_8086&DEV_0886&SUBSYS_13158086&REV_67\4&28D65BF6&0&00E1 PowerManagementSupported = False ProductName = Intel(R) Centrino(R) Wireless-N 6150 Driver ServiceName = NETwNe64 Speed = 130000000 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Intel(R) Centrino(R) WiMAX 6150 AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000003] Intel(R) Centrino(R) WiMAX 6150 ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Intel(R) Centrino(R) WiMAX 6150 DeviceID = 3 GUID = Index = 3 Installed = True InterfaceIndex = 8 MACAddress = 64:D4:DA:6E:97:5E Manufacturer = Intel Corporation MaxNumberControlled = 0 Name = Intel(R) Centrino(R) WiMAX 6150 NetConnectionID = Local Area Connection 2 NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = {12110A2A-BBCC-418B-B9F4-76099D720767}\BPMP_8087_07D7\1&1869C5E3&0&1 PowerManagementSupported = False ProductName = Intel(R) Centrino(R) WiMAX 6150 ServiceName = bpmp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft Wi-Fi Direct Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000004] Microsoft Wi-Fi Direct Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 4 Index = 4 Installed = True InterfaceIndex = 4 MACAddress = 40:25:C2:CB:C2:5D Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&1FFA7BF8&0&11 PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft Hosted Network Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000005] Microsoft Hosted Network Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Hosted Network Virtual Adapter DeviceID = 5 Index = 5 Installed = True InterfaceIndex = 3 MACAddress = 42:25:C2:CB:C2:5D Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Hosted Network Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_SAP\5&1FFA7BF8&0&01 PowerManagementSupported = False ProductName = Microsoft Hosted Network Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft ISATAP Adapter AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000006] Microsoft ISATAP Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 6 Index = 6 Installed = True InterfaceIndex = 5 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\ISATAP_0 PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Teredo Tunneling Pseudo-Interface AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000007] Microsoft Teredo Tunneling Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Teredo Tunneling Adapter DeviceID = 7 Index = 7 Installed = True InterfaceIndex = 13 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Teredo Tunneling Pseudo-Interface PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\TEREDO_TUNNEL_DEVICE PowerManagementSupported = False ProductName = Microsoft Teredo Tunneling Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft Wi-Fi Direct Virtual Adapter Availability = 3 Caption = [00000008] Microsoft Wi-Fi Direct Virtual Adapter CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 8 Index = 8 Installed = True InterfaceIndex = 2 MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Microsoft ISATAP Adapter Availability = 3 Caption = [00000009] Microsoft ISATAP Adapter CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 9 Index = 9 Installed = True InterfaceIndex = 7 MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (SSTP) Availability = 3 Caption = [00000010] WAN Miniport (SSTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (SSTP) DeviceID = 10 Index = 10 Installed = True InterfaceIndex = 34 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (SSTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_SSTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (SSTP) ServiceName = RasSstp SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (IKEv2) Availability = 3 Caption = [00000011] WAN Miniport (IKEv2) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IKEv2) DeviceID = 11 Index = 11 Installed = True InterfaceIndex = 35 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IKEv2) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_AGILEVPNMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (IKEv2) ServiceName = RasAgileVpn SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (L2TP) Availability = 3 Caption = [00000012] WAN Miniport (L2TP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (L2TP) DeviceID = 12 Index = 12 Installed = True InterfaceIndex = 37 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (L2TP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_L2TPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (L2TP) ServiceName = Rasl2tp SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (PPTP) Availability = 3 Caption = [00000013] WAN Miniport (PPTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPTP) DeviceID = 13 Index = 13 Installed = True InterfaceIndex = 36 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPTP) ServiceName = PptpMiniport SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (PPPOE) Availability = 3 Caption = [00000014] WAN Miniport (PPPOE) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPPOE) DeviceID = 14 Index = 14 Installed = True InterfaceIndex = 38 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPPOE) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPPOEMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPPOE) ServiceName = RasPppoe SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (IP) AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000015] WAN Miniport (IP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IP) DeviceID = 15 Index = 15 Installed = True InterfaceIndex = 39 MACAddress = 48:D9:20:52:41:53 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIP PowerManagementSupported = False ProductName = WAN Miniport (IP) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (IPv6) AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000016] WAN Miniport (IPv6) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IPv6) DeviceID = 16 Index = 16 Installed = True InterfaceIndex = 42 MACAddress = 92:CB:20:52:41:53 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IPv6) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIPV6 PowerManagementSupported = False ProductName = WAN Miniport (IPv6) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
WAN Miniport (Network Monitor) AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000017] WAN Miniport (Network Monitor) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (Network Monitor) DeviceID = 17 Index = 17 Installed = True InterfaceIndex = 45 MACAddress = CC:06:20:52:41:53 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (Network Monitor) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANBH PowerManagementSupported = False ProductName = WAN Miniport (Network Monitor) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Network Adapter Configuration
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0 Caption = [00000000] Realtek PCIe GBE Family Controller Description = Realtek PCIe GBE Family Controller DHCPEnabled = True Index = 0 InterfaceIndex = 6 IPEnabled = False MACAddress = 08:2E:5F:8B:27:12 ServiceName = rt640x64 SettingID = {764E3BE0-A159-46CD-A99A-A73E43D42D63}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1 Caption = [00000001] Microsoft Kernel Debug Network Adapter Description = Microsoft Kernel Debug Network Adapter DHCPEnabled = True Index = 1 InterfaceIndex = 9 IPEnabled = False ServiceName = kdnic SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Intel(R) Centrino(R) Wireless-N 6150 Driver DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.2.1 fe809afc:11ff:fe46:b70c Description = Intel(R) Centrino(R) Wireless-N 6150 DHCPEnabled = True DHCPLeaseExpires = 20160502104542.000000-300 DHCPLeaseObtained = 20160501104542.000000-300 DHCPServer = 192.168.2.1 DNSDomain = hsd1.il.comcast.net. DNSDomainSuffixSearchOrder = hsd1.il.comcast.net. DNSEnabledForWINSResolution = False DNSHostName = Rononhp DNSServerSearchOrder = 75.75.75.75 75.75.76.76 192.168.2.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 4096 Index = 2 InterfaceIndex = 10 IPAddress = 192.168.2.115 fe8049c1:6f78:1bc4:a0ca 2002:43ba:6325:0:6064:16bb:8e8e:2cb2 2002:43ba:6325:0:49c1:6f78:1bc4:a0ca IPConnectionMetric = 25 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 128 64 MACAddress = 40:25:C2:CB:C2:5C ServiceName = NETwNe64 SettingID = TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=3 Caption = [00000003] Intel(R) Centrino(R) WiMAX 6150 Description = Intel(R) Centrino(R) WiMAX 6150 DHCPEnabled = True Index = 3 InterfaceIndex = 8 IPEnabled = False MACAddress = 64:D4:DA:6E:97:5E ServiceName = bpmp SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=4 Caption = [00000004] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 4 InterfaceIndex = 4 IPEnabled = False MACAddress = 40:25:C2:CB:C2:5D ServiceName = vwifimp SettingID = {3CB314D6-918B-47C2-BBFC-E9CE958C8332}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=5 Caption = [00000005] Microsoft Hosted Network Virtual Adapter Description = Microsoft Hosted Network Virtual Adapter DHCPEnabled = True Index = 5 InterfaceIndex = 3 IPEnabled = False MACAddress = 42:25:C2:CB:C2:5D ServiceName = vwifimp SettingID = {10EBAE3C-4D76-4B99-8140-40A8DD25D2A8}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=6 Caption = [00000006] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 6 InterfaceIndex = 5 IPEnabled = False ServiceName = tunnel SettingID = {71F3BF0B-2479-4ADA-8DF6-591C181507F2}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=7 Caption = [00000007] Microsoft Teredo Tunneling Adapter Description = Microsoft Teredo Tunneling Adapter DHCPEnabled = False Index = 7 InterfaceIndex = 13 IPEnabled = False ServiceName = tunnel SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8 Caption = [00000008] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 8 InterfaceIndex = 2 IPEnabled = False ServiceName = vwifimp SettingID = {06613EBB-C9CF-46C7-8E4B-6F79CDAC8443}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=9 Caption = [00000009] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 9 InterfaceIndex = 7 IPEnabled = False ServiceName = tunnel SettingID = {9F03691B-1AF9-4041-BB89-DB500DD5ABDD}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=10 Caption = [00000010] WAN Miniport (SSTP) Description = WAN Miniport (SSTP) DHCPEnabled = False Index = 10 InterfaceIndex = 34 IPEnabled = False ServiceName = RasSstp SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=11 Caption = [00000011] WAN Miniport (IKEv2) Description = WAN Miniport (IKEv2) DHCPEnabled = False Index = 11 InterfaceIndex = 35 IPEnabled = False ServiceName = RasAgileVpn SettingID = {7C48CEDB-F5A5-4A54-AB12-477F27A88DDC}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=12 Caption = [00000012] WAN Miniport (L2TP) Description = WAN Miniport (L2TP) DHCPEnabled = False Index = 12 InterfaceIndex = 37 IPEnabled = False ServiceName = Rasl2tp SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=13 Caption = [00000013] WAN Miniport (PPTP) Description = WAN Miniport (PPTP) DHCPEnabled = False Index = 13 InterfaceIndex = 36 IPEnabled = False ServiceName = PptpMiniport SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=14 Caption = [00000014] WAN Miniport (PPPOE) Description = WAN Miniport (PPPOE) DHCPEnabled = False Index = 14 InterfaceIndex = 38 IPEnabled = False ServiceName = RasPppoe SettingID =
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=15 Caption = [00000015] WAN Miniport (IP) Description = WAN Miniport (IP) DHCPEnabled = False Index = 15 InterfaceIndex = 39 IPEnabled = False MACAddress = 48:D9:20:52:41:53 ServiceName = NdisWan SettingID = {7E64B8CF-4F9E-4FF7-84EF-EE49248F8A17}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=16 Caption = [00000016] WAN Miniport (IPv6) Description = WAN Miniport (IPv6) DHCPEnabled = False Index = 16 InterfaceIndex = 42 IPEnabled = False MACAddress = 92:CB:20:52:41:53 ServiceName = NdisWan SettingID = {36EEC40B-BDC1-46E7-BCE5-CDD237CCE5FA}
\RONONHP\root\cimv2:Win32_NetworkAdapterConfiguration.Index=17 Caption = [00000017] WAN Miniport (Network Monitor) Description = WAN Miniport (Network Monitor) DHCPEnabled = False Index = 17 InterfaceIndex = 45 IPEnabled = False MACAddress = CC:06:20:52:41:53 ServiceName = NdisWan SettingID = {894CD965-B795-4C1E-A653-97A5B27D620D}
Computer System
RONONHP AdminPasswordStatus = 3 AutomaticManagedPagefile = True AutomaticResetBootOption = True AutomaticResetCapability = True BootROMSupported = True BootStatus = 0 0 0 0 0 0 0 0 0 0 BootupState = Normal boot Caption = RONONHP ChassisBootupState = 3 CreationClassName = Win32_ComputerSystem CurrentTimeZone = -300 DaylightInEffect = True Description = AT/AT COMPATIBLE DNSHostName = Rononhp Domain = SURFHOME DomainRole = 0 EnableDaylightSavingsTime = True FrontPanelResetStatus = 3 HypervisorPresent = False InfraredSupported = False KeyboardPasswordStatus = 3 Manufacturer = Hewlett-Packard Model = HP Pavilion dv7 Notebook PC Name = RONONHP NetworkServerModeEnabled = True NumberOfLogicalProcessors = 8 NumberOfProcessors = 1 OEMStringArray = \(HP\) LOC#ABA ABS 70/71 78 79 7A 7B CNB1 068C210002204710000622100 HP_Mute_LED_0_0 PartOfDomain = False PauseAfterReset = -1 PCSystemType = 2 PCSystemTypeEx = 2 PowerOnPasswordStatus = 3 PowerState = 0 PowerSupplyState = 3 ResetCapability = 1 ResetCount = -1 ResetLimit = -1 Roles = LM_Workstation LM_Server Print NT Potential_Browser Backup_Browser Status = OK SystemFamily = 103C_5335KV G=N L=CON B=HP S=PAV
SystemSKUNumber = A6X02UA#ABA SystemType = x64-based PC ThermalState = 3 TotalPhysicalMemory = 8535257088 WakeUpType = 6 Workgroup = SURFHOME
Log Contents
5/1/2016 10:48:55 AMObject Recognition Initialized. 5/1/2016 10:48:56 AMCamera Initialized: EZB://192.168.1.1 @ 320x240 5/1/2016 10:48:56 AMObject Recognition loaded. 5/1/2016 10:48:59 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbEZ-B v4 Camera Error: System.TimeoutException: The operation has timed out. at EZ_B.EZBv4Video.AQE6unH900(Int32 , Object ) 5/1/2016 10:48:59 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbCamera Disabled 5/1/2016 10:51:12 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:15 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:15 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:51:36 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:39 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:39 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:51:50 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:53 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:53 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:04 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:07 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:07 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:14 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:20 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:20 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:48 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:51 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:51 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected
#63
ICMP Response
Wifi Adapters
Network Adapters
Intel(R) Centrino(R) Wireless-N 6150 AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Intel(R) Centrino(R) Wireless-N 6150 Driver ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Intel(R) Centrino(R) Wireless-N 6150 Driver DeviceID = 2 GUID = Index = 2 Installed = True InterfaceIndex = 10 MACAddress = 40:25:C2:CB:C2:5C Manufacturer = Intel Corporation MaxNumberControlled = 0 Name = Intel(R) Centrino(R) Wireless-N 6150 NetConnectionID = Wireless Network Connection NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_8086&DEV_0886&SUBSYS_13158086&REV_67\4&28D65BF6&0&00E1 PowerManagementSupported = False ProductName = Intel(R) Centrino(R) Wireless-N 6150 Driver ServiceName = NETwNe64 Speed = 72000000 SystemCreationClassName = Win32_ComputerSystem SystemName = RONONHP TimeOfLastReset = 20160422033649.493246-300
Computer System
Log Contents
5/1/2016 10:48:55 AMObject Recognition Initialized. 5/1/2016 10:48:56 AMCamera Initialized: EZB://192.168.1.1 @ 320x240 5/1/2016 10:48:56 AMObject Recognition loaded. 5/1/2016 10:48:59 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbEZ-B v4 Camera Error: System.TimeoutException: The operation has timed out. at EZ_B.EZBv4Video.AQE6unH900(Int32 , Object ) 5/1/2016 10:48:59 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbCamera Disabled 5/1/2016 10:51:12 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:15 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:15 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:51:36 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:39 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:39 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:51:50 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:51:53 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:51:53 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:04 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:07 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:07 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:14 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:17 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:20 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:20 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 10:52:48 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 10:52:51 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 10:52:51 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 11:10:41 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbAttempting connection on 192.168.1.1:23 5/1/2016 11:10:44 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 11:10:44 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.ezbDisconnected 5/1/2016 11:12:22 AMObject Recognition Initialized. 5/1/2016 11:12:22 AMCamera Initialized: EZB://192.168.1.1 @ 320x240 5/1/2016 11:12:22 AMObject Recognition loaded. 5/1/2016 11:12:25 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.EZBEZ-B v4 Camera Error: System.TimeoutException: The operation has timed out. at EZ_B.EZBv4Video.AQE6unH900(Int32 , Object ) 5/1/2016 11:12:25 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.EZBCamera Disabled 5/1/2016 11:13:00 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.EZBAttempting connection on 192.168.1.1:23 5/1/2016 11:13:03 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.EZBConnection Failed: System.TimeoutException: The operation has timed out. at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 5/1/2016 11:13:03 AMC:\Users\Public\Documents\EZ-Builder\Examples\JD.EZBDisconnected
#64
Looks like The operation has timed out and JD.EZBDisconnected. What do you need from us?
