EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Compass Heading Tracking
I have been messing with this for a while and can't make progress. I want to track forward on a set compass heading. If there is a variation from the heading I want to make a correction turn back toward the heading. I have made the compass to read with a +/- 5 degree tolerance. For setup I am using a deviation of 30 degrees, but will narrow it to 10 degrees once it is working.
$compass_setting = 150
$compass_setting2 = $compass_setting + 30
$compass_setting3 = $compass_setting - 30
:loop
  if ($CompassHeading = $compass_setting)
    Forward()
  endif
  if ($CompassHeading = $compass_setting3)
 Left()
endif
  Goto(:loop)
I have tried a number of variations but no luck.
Any ideas?
Ron
Oh, i should add that since you are using continuous rotation servos for moving... that you can also adjust the speed in which the robot moves.
So you could do something like this...
SayEZBWait("Which direction shall i face?")
$Speech_Response = (WaitForSpeech(5, "East", "West"))
if ($Speech_Response = "East")
  SayEZBWait(("I am moving" + $Speech_Response))
  $DirectionToFace = 90
elseif ($Speech_Response = "West")
  $DirectionToFace = 180
else
  SayEZBWait("I didn't hear you")
  # Stop running this script
  Halt()
endif
ControlCommand("MPU9150", Init)
repeat($count, 0, 10, 1)
  ControlCommand("MPU9150", RunOnce)
  if ($CompassHeading < $DirectionToFace)
    SetSpeed(50)
    Right()
  else
    SetSpeed(50)
    Left()
  endif
  sleep(1000)
endrepeat
ClearVariable("$count")
Here's the Blockly workspace: facecompassdirection.ezblockly
Hi Dj,
I will load it and give it a try. My friend will have another skill added to the list.
I run a bunch of separate codes. One is the Radar avoidance, facial tracking moving the head, tracking moving the eyes, (the camera is mounted under her nose) and compass tracking. The voice is a Cepstral male voice (for now). His name is Antonn. He enjoys having conversations using responses to questions and when he gets lazy he makes requests to Alexa. He also runs light and outlet controls which I built (before the many smart devices became available). It is nice to ask him to make coffee in the morning and letting me know when it is done, or operating lights.
Thanks for the code,
Ron
