Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
I have a problem when I compile EZ-SDK
The error below:
c:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1605,5): warning MSB3274: The primary reference "EZ_B" could not be resolved because it was built against the ".NETFramework,Version=v4.5" framework. This is a higher version than the currently targeted framework ".NETFramework,Version=v4.0". c:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1605,5): warning MSB3275: The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the assembly "aForge, Version=2014.1.21.0, Culture=neutral, PublicKeyToken=c3a3457c97d352d9" which was built against the ".NETFramework,Version=v4.5" framework. This is a higher version than the currently targeted framework ".NETFramework,Version=v4.0". c:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1605,5): warning MSB3275: The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the assembly "EZ-QRCode, Version=0.0.0.0, Culture=neutral, PublicKeyToken=c3a3457c97d352d9" which was built against the ".NETFramework,Version=v4.5" framework. This is a higher version than the currently targeted framework ".NETFramework,Version=v4.0". c:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1605,5): warning MSB3275: The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the assembly "FFMPEG, Version=2013.8.13.0, Culture=neutral, PublicKeyToken=0c913eb082202b8e" which was built against the ".NETFramework,Version=v4.5" framework. This is a higher version than the currently targeted framework ".NETFramework,Version=v4.0". CoreResGen:
My OS is Win7 64, but I have set the X86 run.
Thank you
Thank you so much. The code can be worked in my computer.
Don't forgot to mark your question answered. Unless you are still having an issue?
Twitter YouTube
I also had this problem when adding a reference to the EZ-B library from NuGet even with the project as x86 . I'm using Visual Studio Express 2015.
When adding a reference to the DLL locally, everything worked fine.
