Connect By Name with EZ-B v3
Connect By Name With EZ-B V3
I’m dusting off an older rover that still runs an EZ-B v3 over Bluetooth and trying to make my ARC project more "plug and play" across two Windows laptops. The v3 pairs fine and shows up as two COM ports (SPP), but the COM number keeps changing between machines or after re-pairing (e.g., COM4 one day, COM7 the next). In ARC’s Connection control I can connect when the COM is correct, and I’m using a simple script to trigger it:
ControlCommand("Connection", "Connect", "0")
However, that relies on the preconfigured COM. I added the EZB Connect By Name skill hoping it could discover my controller by a friendly name (I renamed the Bluetooth device to "DriveBase"), but the log window stays empty and it never finds anything. I’m guessing that skill listens for the EZ-B WiFi broadcast (v4+) and not Bluetooth/serial from the v3.
Is there any supported way in ARC to connect to an EZ-B v3 by its Bluetooth device name (or otherwise auto-select the right COM) instead of hardcoding a COM port, or is there a recommended workflow/script to resolve the correct COM by Windows device name before issuing the Connection command?
EZ-B V3 by EZ-Robot
EZ-B v3 works with Synthiam ARC via Bluetooth COM port to control servos, sensors, scripts and robot skills.
Bluetooth
EZ-B Settings by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
EZB Connect By Name by Synthiam Inc.
Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC.
You’re correct: EZB Connect By Name is for EZ-B WiFi broadcasts like the EZ-B v4 / WiFi controllers, not for EZ-B v3 Bluetooth serial. The v3 does not advertise the same network broadcast, so that skill won’t detect it.
What you can do with an EZ-B v3
For EZ-B v3 over Bluetooth, ARC ultimately connects through a COM port, so the practical options are:
1) Use a fixed COM port in Windows
If you can keep the Bluetooth SPP port assigned consistently on each laptop, that’s the simplest workflow.
In Windows Bluetooth settings / Device Manager, you can sometimes reassign or keep the COM pair stable by:
  • removing the device
  • re-pairing it
  • checking the incoming/outgoing COM ports under Ports (COM & LPT)
  • making sure no other app is holding the port open
2) Use a small startup script to detect the EZ-B COM port
ARC can’t directly connect to an EZ-B v3 by Bluetooth device name the way it can by WiFi broadcast name, but you can write a script that:
  • scans available COM ports
  • tries the most likely one(s)
  • then issues the connection command once the correct port is found
ARC’s scripting has COM.availablePorts() and related COM functions, so you can build a little auto-detect routine. The exact implementation depends on how your ARC project is set up and whether the EZ-B v3 exposes a recognizable response on the port.
If you want plug-and-play across two laptops, I’d suggest one of these:
Best simple option
  • Keep the v3 paired on each laptop
  • Use the same COM assignment on both machines if possible
  • Save the ARC project with that COM configured
Better automation option
  • Add a startup/Init script that checks available COM ports
  • If your project only ever uses one Bluetooth robot controller, the script can try each port until it finds the EZ-B v3
Important limitation
There isn’t a built-in ARC feature that will resolve an EZ-B v3 by Windows Bluetooth device name and automatically bind it to the Connection skill. That name exists in Windows Bluetooth, but ARC’s connection is still COM-based for v3.
Relevant docs
If you want, I can help you build the auto-COM detection script
If you tell me:
  1. whether the v3 shows up as one outgoing COM port or two ports in Windows, and
  2. what the exact ARC Connection skill is named in your project,
I can draft a JavaScript init script for ARC that tries the available COM ports and connects automatically.
Also, for this kind of scripting, the built-in ARC AI Assistant can be handy because it can help rewrite the script right inside ARC:
