#17
PWM is simple to set up.
Assuming you have connected as the tutorial video using the 5th signal wire for both enable pins, add a PWM control and assign it to the port that is connected to the enable pins. The higher the PWM the faster the motors will spin.
You could use a script too using the PWM() command but why complicate what's simple?
France
#18
I'm having with another H bridge. I wish you informed.
thank you for your help
#19
Can you post a picture of your last wiring setupi?
France
#20
Hi,
Voila the last wiring
I have connected only the motor B (out B) and it's good with: In3 = D3 (ext) In4 = D4 (ext) ENB = D6 (ext) / config in PWM +5v = D16 (+5) ==> my motor works very good
If I connected only the motor A (out A) and it's bad with: In1 = D1 (ext) In2 = D2 (ext) ENB = D7 (ext) / config in PWM +5v = D16 (+5) ==> my motor doesn't work (not even a noise)
Part A out is defective. It seems to me that this card can suporter two engines windshield ice. I just order another
H Bridge
#21
Great, that's how it should be wired!, nice job...its a shame your hbridge is faulty.
#22
Yes, Looks good. Keep your head up. I burnt up three H-Bridges before I got everything working.
Keep in mind you may beed a more heavy duty H-Bridge then what you ordered. Pololu has some nice ones that will work at a good price. You'll need to know how many amps your motors pull and the operating voltage.
Brazil
#23
Hi.. So if I get it rigth, if I want to use a diferent power source only for the motors, I should wire that to the Vcc and ground on the h-bridge, Is that correct? And do I need to connect the 5v To Ez-B too? Thanks...
#24
I just fitted one of these to Jarvis
Basically, 5 signal wires, D15 to D19 to each of the In1-In4 plus PWM split to both enables. VCC from battery to VCC on H-Bridge Ground from D19 to H-bridge ground Vcc from D19 to H-Bridge 5V
