#17
Finally got around to it, I believe it's wired up right; Put PTP's code in, hope all goes well! lol
Seems to be working! Although the old RAD motor gear boxes seem worn:( not engaging well) Took apart gearboxes and reseated them, works now! But NO REVERSE?
I have both treads going FWD, Left Turn,Right Turn....No Reverse:( PTP, I double checked the code you have here, in my Script...
#19
If you have turn left and turn right set up so that motor 1 rotates one direction and motor 2 rotates the other then reverse should work. Check both motors are rotating when you turn.
#20
Yes, they both turn opposite to each other, in reference to left or right. and FWD. I hit reverse arrow in EZB and nothing.
