TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Connecting A Wii Balance Board
Hi, I'm just finishing an example Python script for wiimotes. Has anyone had success in connecting a balance board? I can successfully connect a wiimote using "EZ_B.WiimoteLib.Wiimote.Connect", but this does not appear to work for the balance board. Looking through the provided XML list of commands and the .dll info, I can't find a connection command for the balance board. Any ideas? David.
like the idea, but have no idea on what to do. sorry.
I've never tried a balance board. The code is there, but haven't seen if it actually works. That why ARC doesn't have a module for it... At least not yet:)
Ill add it to the very long list of things to do
Have you ever thought about sending sound to the Wiimote? It would be a great way to get feedback from a robot.
For the Wiimote, I have rumble working in Python, and the four IR points, as well as the accelerometers.
It's an amazingly sophisticated input device, considering you can pick them up on Ebay for $10.
I have tried but can't find any reference code
