Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Connecting Brookstone Rover To ARC Questions
Hi all,
I am trying to connect my Rover v1 to ARC. I have tried two different ways:
  1. Connect the rover to my wifi on the computer first. When I tried this the network symbol has the yellow triangle with the black line appeared. I then opened ARC and added the Rover, selected v1 and press connect. I then get this message:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 12/09/2014 10:11 PM - TCP Server stopped 12/09/2014 10:11 PM - TCP Server stopped 12/09/2014 10:11 PM - TCP Server stopped 12/09/2014 10:11 PM - TCP Server stopped 12/09/2014 10:11 PM - TCP Server stopped 12/09/2014 10:11 PM - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at EZ_Builder.UCForms.FormBrookstoneRoverMovementPanel.(Object , EventArgs )
  1. I have tried to leave my wifi connection on to the computer, opened ARC, add the robot and press connect. This freezes ARC and when it responds I get this message: EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 12/09/2014 10:13 PM - TCP Server stopped 12/09/2014 10:13 PM - TCP Server stopped 12/09/2014 10:13 PM - TCP Server stopped 12/09/2014 10:13 PM - TCP Server stopped 12/09/2014 10:13 PM - TCP Server stopped 12/09/2014 10:13 PM - System.Net.Sockets.SocketException (0x80004005): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at EZ_Builder.UCForms.FormBrookstoneRoverMovementPanel.(Object , EventArgs )
Plz help?
Another thing I want to try connect to the rover remotely so I can control it while a I am at work. How can I do this? stress stress stress stress
Have you turned off Windows firewall.I had issue with connecting my tablet to my computer with the http server from ezb control option.Are you using ezb 3 or v4?
No I don't think so. How do I turn it off I am only new to it. I think I am using v4.
Thanks
konradmx what pc do you have
It's really easy to tell the EZB4 and EZB3 apart... If you bought your ezb controller just recently then it will be the V4... Below is the v4...
The Brookstone Rover module has a bug while we are adding support to v2. I didn't notice it until this message. I'll do a new release for the v1 users tonight or tomorrow.
I don't have either I though all I need is the ex builder? What do I need to get this to work?
I am using a hp windows pc
