Hi guys I have an ez-b v3 how do I connect it to a Windows 8 pc
wall e lover 360
— Edited
8 Participants
DHT11 Temp & Humidity Sensor
— Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables.
Hey guys surprize surprise I am a kid I'm only 12 yrs old.
On my windows tablet on bluetooth it shows the ez-b but there is no button that says connect the only button there is forget item
Not sure why your profile isn't working. Sorry I thought you might be trolling us. If any of the advice we gave helped, please mark this as resolved giving credit to whoever helped the most. If you are still having problems, let us know what is happening so we can help.
Always happy to help kids get started in Robotics.
Thanks for helping but I still can't get it to connect
All so I tried connecting it once and the board made a laude sound and then the board shut off
By loud sound, you mean like a loud pop? You probably wired the power backwards. Check the two fuses, but the board could be cooked. The v3 (and most electronics) do not like having power applied backwards.
No man I know my positives and negatives. The board was on for a wile and then when I tried to connect the board to my tablet it maid a sound almost like a servo went of and it lasted for about 3 seconds it actually happened twice.
Ok. Back to the Bluetooth. Oncw you are paired, you need to determine which comm ports windows assigned (watch h the tutorial). You don't need to tell Windows to connect again, you need to have ARC connect to the assigned comm port. You need to do it within 30-45 seconds of powering up the EZ-B, similar to how you had limited time to pair it. (we'll ignore the weird sound for now as long as the board powers up and Windows sees it).
