Ubtech Alpha 1 Bluetooth icon Ubtech Alpha 1 Bluetooth — Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs. Try it →
No, don't try to connect the battery to the i2c port. You need to connect the positive and negative wires of the battery to the barrel adapter and plug it in to the side of the EZ-B's power shell. The smaller wires on the battery are for charging the battery with a LiPo charger.
Your using the power input which is on the bottom of the stacked pcbs (mini dean connector), else you use the power base the board comes connected to. If you are not familiar with lipos please research before using them since they can be dangerous if used incorrectly. Check out the lessons for powering up your board: Lessons
How I did mine was to cut off the main connector and connect the wires to the barrel jack terminals (make sure polarity is correct), but there are adapters available too. Or you could use a mini deans connector that would connect to the EZ-B without the power base.
Quote:
I want to connect a lipo battery 7.4v to the EZ-Bv4 unluckily I don't know which port I need to use
... How about the mini deans battery connector on the bottom of the ezb4 board? Seriously don't plug anything in until you see here on how to power your ezb... Powering your ezb4
Ways to power the board are either through the barrel connector or to connect or replace the mini dean connector. Steve G's method of just replacing the barrel connector i s probably your safest method since it will keep the fuse in line with your board.
Switzerland
Thanks for all of your comments it helped well;)
No problem. Glad the advice helped. If you find that the battery wires are too thick to go in to the barrel jack terminals, you could connect the battery wires to a terminal block, the use some thinner grade wire from the block to the jack. :)
