EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Well that's a first.... I have never heard of anything like this before. Maybe your ezb4 is some sort of custom board or prototype?.... Where did you buy your JD from? EZ Robot is probably going to have to help you out on this one....
I think there should be no password by default. If it is asking for password and you don't know the password. Then reset the robot to get rid of password.
Thanks, --Rajnish
@aes24
Rajnish is correct, no password is required by default. Please use something sharp and press the small reset button on the top of the EZ-B while the power is on to reset the network settings.
Looks like you need to reset the ezb to factory settings. Where did you purchase the robot from?
is it not the password off your wifi pc?its a long number.
