Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Yes, but both will move the same. You can buy Y adaptors for servo cables which do this.
Italy
Yes, i want them to move the same.
So, i can solder the cables and them will move both. Is it right?
Did you know that you can also control more than one servo from any control in ARC? Press the Multi servo button next to the servo selection when selecting a servo.:) But yes, it uses more ports. I'm mentioning this, in case you're unaware of the software solution - vs modifying hardware.
Boom, and then he one upped us all:) , another feature for less work.
