Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Connecting To Arduino Using A Script
How would you use a script to connect to an Arduino that is connected to your SCB that is running ARC? As part of the robots initialization I would like to connect to all the the Arduino’s programmatically.
USB
Servos 12
ADC 6
Digital 14
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills.
Com Port Manager by Synthiam
Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART.
The one thing that I hope the new ARCx software does is decouple from everything EZB that is not specifically related to the EZB controllers.  Like in the EZB controller skill. It should be something like ARCx controller skill.
That's a great point! The idea of generalizing the terminology and functionality in ARCx to be more inclusive of various hardware platforms, not just EZB controllers, could indeed make the software more versatile and appealing to a broader range of users and applications. This approach would enhance the adaptability of ARCx, allowing it to seamlessly integrate with a wider variety of devices and controllers, thereby expanding its usability in diverse robotic projects.
If this change is implemented, it would likely involve updating the interface, documentation, and possibly some underlying code to ensure compatibility and ease of use across different hardware platforms. It would also mean that users like yourself could more intuitively connect and configure various types of controllers without being bound to a specific brand or model.
Your feedback is valuable, and it's great to see users contributing ideas that could shape the future development of the software. If you have more suggestions or specific features you'd like to see in ARCx, sharing these with the Synthiam community or through official feedback channels could help influence future updates.
There might be a misunderstanding about what "EZB" refers to. The term "EZB" is not exclusive to products made by EZ-Robot. Rather, "EZB" stands for any microcontroller equipped with EZB firmware. This firmware transforms a standard microcontroller into an "easy board," simplifying its use significantly.
For example, the EZB product sold by EZ-Robot is essentially a microcontroller that comes pre-installed with this specialized EZB firmware. However, if you were to install EZB firmware on an Arduino, that Arduino would then also be classified as an EZB.
It’s important to note that a microcontroller with this firmware should not be confused with ARCx, which is software, not hardware.
For a more detailed explanation and additional resources, the "How to Build a Robot" tutorial might be helpful. You can access it here: https://synthiam.com/Support/Get-Started/how-to-make-a-robot/EZB.
Thank you for the clarification, DJ! Your explanation helps to distinguish between the EZB firmware and the ARCx software, emphasizing that "EZB" refers to any microcontroller that operates with the EZB firmware, not just those specifically from EZ-Robot. This distinction is crucial for understanding how various devices can be integrated and utilized within the ARC ecosystem.
For users looking to expand their projects, understanding that they can convert different microcontrollers into an EZB by installing the appropriate firmware opens up a lot of possibilities. This flexibility allows for a broader application of the ARC software across various hardware platforms, making it a versatile tool for robot enthusiasts and developers.
If anyone has further questions about setting up their microcontroller with EZB firmware or integrating it with ARCx, they can refer to the provided tutorial or ask more detailed questions here for specific guidance. Your insights are invaluable in helping users maximize their use of Synthiam's resources and capabilities.
