BV4615 RC-5 IR Decoder icon BV4615 RC-5 IR Decoder — Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported. Try it →
Hey guys. I just got my ez-b v4 today and I'm having trouble connecting a couple of desktops (win7 home premium 64-bit) to it, even with windows firewall turned off. my laptop (win7 pro 32-bit) connects fine. Do you have any suggestions, pointers, directions, etc. I could follow to resolve the issue? I really appreciate any feedback you can give. Thanks! rb
I think he is trying to connect in AP mode.
I would advise to connect to the EZ-B with the computer that works and then use a web browser to connect to the EZ-B on 192.168.1.1. At that point, give the EZ-B your networks SSID and Password. This will allow it to get onto you network. You will hear the EZ-B say "I am connected to your network" when you have a connection. Next, you need to know what IP address was assigned to the EZ-B. Connect to your router's IP address next with a computer connected to your network. You will probably be prompted with a username and password. Enter this information for you router. In your router configuration, you should see an option that shows connected devices. This may be under a heading called DHCP. Look for the EZ-B. Get the IP Address assigned to your EZ-B and then use that in the connection options in ARC. Be sure to include the :23 on the end of it.
I suspect what is happening is that one of the wifi cards works great with the EZ-B. The other two are probably older and having issues. The wifi cards that are not connecting, but can connect to your network will then be able to use your network to connect to the EZ-B unless you have an old WIFI access point, which then you would probably want to replace that anyway.
You can also find the IP address of the EZ-B once on the network by using the network scan tool from within ARC.
Thanks guys! I am indisposed at the moment but I will give it another go on Monday.
I managed to get it on. I mean the EZ-B. Buster Junior will live because of your efforts. Many thanks from Jr. and the bookmaker.
@bookmaker32, What did you do that ended up working for you? Please share so others can learn from your good fortune! :)
#15
@Dave Schulpius , I followed @d.cochran advise and all went smoothly. I am now connected to my router and when I power up my EZ-Bv4 it instantly connects. Also with this method my computer stays connected to the internet. Life is good!
#16
Yeah, @d.cochran is a pretty smart guy. He helped me out a lot when I was having my connection issues. We're lucky to have him here on this forum. :)
