Irobot Roomba Legacy icon Irobot Roomba Legacy — Legacy iRobot Discovery and 4xxx control via EZB software-serial (D0), supports Arduino/EZ-Robot, adjustable baud rate; not for hardware UART/USB Try it →
Connection Issue - Newbie Question
Hi all.
I saw the video of the 'real walle' and decided that I needed one!!
So last christmas I bought myself a Wall-E and a EzB kit. And as a newbie it took me months before I pulled Wall-E apart. It took me a while longer to order all my parts - cos I needed ALL of my parts before I began;) (did i mention i'm a newbie?! lols!)
In the last month I've tried to connect my board to my laptop (its only taken me 4 months to finally do it!) - I'm running Windows 7 with a bluetooth adapter. The board pairs with the laptop fine but when I start the program and press connect, it connects for like 2 seconds then a pop up windows comes up telling me its not connected and the small light goes back to blinking at me. stress
And I'm completely clueless... help
I've tried to rechargeable batteries first then loaded newly bought batteries. The BF then told me to use a power supply (only 2amp - have no idea if that's enough? - the fuse didn't blow so I assume that's good sign.). I've tried two other computers/laptops and same results?
Any suggestions to what I'm doing wrong? (I thought this would be an easy project but I can't even get it connected stress )
Have you updated the Firmware on the board?
If yes did the firmware updater work ok?
If no then try updating it.
Then report back welcome to the forum btw. No doubt someone else will jump in with some other suggestions we are a very helpful community here.
I had the same issue with my board and it was because it was "browning out". Too many things pulling too much current. I took care of it by powering my servos directly from the battery (the regular size servos that is - the mini servos remain attached to the board). And Welcome to the Community!!!
Thanks for the quick responses!
So... I can't update the board cos it won't connect long enough to do anything... it won't connect at all (except for like 2 secs!). FYI, I get this error:
Attempting connection to COM5 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String portName) Disconnected
There's nothing connected to my board at all... no servos, nothing.
I've been trying to connect it to the program first before I start attaching things to it and I can't even seem to do that...
Any chance in the world that I have a dud board? stress
Netherlands
Hi PriNceSs.Try connecting something to your board first like a ping sensor. I've noticed that my board has connection problems too when nothing is connected to it. As soon as I add something to the ports it connects fine. I hope you get it to work, allthough theres always a chance that things might be faulty or dead, one can assume that it is not. Keep trying, I'm sure youll figure it out. ;)
Princess, can you verify against the tutorial videos that your bluetooth software is the same as the videos?
People with third party bluetooth software always experience connection issues. It's a bug in their software, so there is nothing we can do about it - other than tell you to uninstall.
You should have two COM ports detected. If you don't, then you do not have the native Microsoft Windows Bluetooth Stack. There is info about it in the Tutorial section under Adding Bluetooth.
Yeps, can confirm that it is the native software... and yes, I get the two com ports (com5 and com7) but can't connect to either one of them. I've tried with two different laptops (one with a bt adapter and the other is built-in).
Okidey- have tried to have something connected but no luck. The BT light stays on for 4 seconds instead of two seconds - not that it helps?
Ecuador
Maybe you will need to Re install windows.... format everything....
I have 2 computers... the 2 computers has windows 7... One of the computers I have not formatted for a long time!! maybe 2 years...... and when I try to connect my Ez-Board... I can pair the Ez-Board with the computer... but I can not connect the Ez-Board with ARC... Is because something is wrong with windows...
But I have my new netbook.... Acer Aspire one 722 (The same that Dj:) jaja) and Ez-Board works Perfectly!!! With out problems!! and with a generic Bluetooth!!
try it!! Good luck!
