Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Connection To Wifi
I am new to this game. Bought JD robot for grandkids. Got through building it but have trouble with wifi. I have found I have disconnect my wired line to router to connect to internet to get ARC to connect to JD. However When I try to align the servos the connection is lost and I can not reconnect. Of course without my internet connection I can not talk to ex-robot.com. Can anyone help me? stress
To be clear I think you mean wifi connection to the robot not internet connection? ... Have you followed the entire connection tutorial here? EZB4 connection Tutorial and this one too EZB4 Wifi modes The second one will help you put JD in client mode so you can connect to him and the internet at the same time....
Also make sure the battery is fully charged....
Richard,
I had not read the EZB Wifi modes. This clears up a lot of my questions. I will try going through the process described and see if that fixes my problem. I suspect it will.
Rob S
I am having no problem connecting in AP mode, which I am using successfully. I was not able to make Client mode work which I suspect is related to the password. However I don't need Client Mode for now so I will close this Thread.
