Drone Collision icon Drone Collision — Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance Try it →
Connectors, Sockets,Housing
If anyone is looking to make there own connectors you can get some nice crimpers, I use them a lot, that work on just about any pin type. They are 45 dollars, not bad considering that the one designed for a specific pin type will probably run you 250 to 300 dollars. They are at Digikey.com a company that is very nice to deal with. I also included the socket and the housing numbers. Although I find that I have better luck in my project just crimping on a socket to the wire then putting heat shrink on the socket/wire individually. Good luck!
https://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=wm9999 https://www.digikey.com/product-detail/en/0016020086/WM2510CT-ND/467802 https://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=wm2801
