XV Lidar Bridge icon XV Lidar Bridge — Neato XV LIDAR integration for ARC with live radar, 8-zone obstacle detection, NMS support, calibration, and scan watchdog monitoring Try it →
Contest :) Help Identifying A Replacement Capacitor
I have a DC to DC converter but a cap is torn off and is too damaged to solder. There are no legs to solder to. Anyways find me a economical replacement , and you get 2 higher torque 385 mabuchi 6 to 12v motors , excellent replacements for the rad robot with longer body but same diameter shaft. Shipping outside the USA you pay for. Okie dokie! Post where I can buy it in the USA from a store. Ebay does not count. Post the specs as you read them too:)
Dang and troy is even giving you a tool to help :)
Someone should get it soon! lolol
We shall see jeopardy music;)
I purchased 8 Of these and I won't use them all so I figure I could share the extra robot parts goodness:)
I've used those motors on a powerwheels quad, with the powerwheels gearbox it pulled my 35lb daughter up steep hills with little trouble.
Judging by the size its a 2.2 microfarad electrolytic cap with a 35v rating
It looks like a 330uf cap @ 35volts.
