Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Continuous Servo Movement Panel
I have an ezb3 and am using the Continuous servo Movement Panel window with the old 360 motors but it doesn't seem to do anything. I read the manual and it says that it has to be connected to board#0 I have that,I also checked the port numbers and they are good, but still nothing happens. When I use the Continuous servo window they work well but not with the panel. Is there anything that I can do differently? I have the latest ARC and the latest ezb3 firmware
A.bautista
did you messure that batteries? its better to use the lipo batt.
Did you set the servo speed with a pwm
Never mind... you have tried all my suggestions...
Maybe reboot, reinstall and try again?
Ok, possible issue ( I don't have my ezb3 handy in order to test this)... I believe the servo values when using the ezb3 should be min 1 and max 100.... centre or stop is 50... When using the ezb4 servo values are min 1 and max 180.... centre is 90...
Have you tried setting the servo values to 1 and 100 instead of 1 and 180? Stop value at 50?
  1. Check the ports are set correctly in the Movement Panel config.
  2. Check the forward and reverse values are set correctly in the Movement Panel config.
If that doesn't work a workaround is to use a custom Movement Panel and use script commands to set the servos moving. Simply use the Servo() commands with the relevant port numbers and positions to suit the direction and speed.
i.e. Forward (assuming servos are opposite each other);
Servo(D0, 180)
Servo(D1, 1)
Reverse (assuming servos are opposite each other);
Servo(D0, 1)
Servo(D1, 180)
Stop (taking in to account modified servos may differ);
Servo(D0, 92)
Servo(D1, 89)
@Rich... He is using an ezb3, so shouldn't the servo values be min=1 and max=100?
Probably:) Although the exact values for straight movements will need to be found regardless of V3 or V4.
