Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
I am not sure how you would execute it, but you would need to put the whole ControlCommand string in quotes for the variable to accept it.
I would instead make a $gender variable and use it in the control command, like this:
$gender = "Female"
ControlCommamd("Speech Settings",SetVoiceGender,$gender)
Tanks Alan,
The variable within the ControlCommand is working.
I am looking to simplified the use of ControlCommand to switch gender in a script where I establish a dialog between my PC and EZB
here's an example:
ControlCommand("Speech Settings", SetVoiceGender, "Female")
Saywait("who are you?")
ControlCommand("Speech Settings", SetVoiceGender, "Male")
SayEZBwait("I am EZB ")
I am wondering if it's be possible to switch gender within the "Say" command.
By the way it's fun and plenty of possibility to listen both unit chanting together.
I would do something like this, although could get even more elegant by having the phrases in text files and doing "FileReadLine" commands so the script is just a few subroutines.
note: untested --
goto(female)
saywait("who are you")
goto(male)
SayEZBWait("I am EZ-B")
goto(female)
saywait("What is your favorite color?")
goto(male)
SayEZBWait("Blue")
goto(end)
:male
ControlCommamd("Speech Settings",SetVoiceGender,"Male")
return
:female
ControlCommamd("Speech Settings",SetVoiceGender,"Female")
return
:end
As far as I know ControlCommand does not return a value (in this case anyway) so you can't assign it to a variable...
You'll have to do something like below...
saywait("am I male or female")
$g=WaitForSpeech( 30, "male",female") #script will wait 30 seconds for your answer
if($g="female")
$gender="female"
#do something here
else
$gender="male"
#do something else here
endif
Ricahrd,
Will your script work with that space inside the parentheses after the $g=WaitForSpeech( ?
Does EZ Script ignore spaces?
@Dave... yes Spacing can be good for readability....
@Alan Your code example is working fine and will simplify my script. Text file usage is also a great idea.
@ Richard Tanks for your suggestion
gilles
