Camera Device icon Camera Device — Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts Try it →
Control Ezb From Mobile
Hi I would like to know if it s possible to use app mobile to control ezb from my iphone without using wifi.? I would like to use web browser( app mobile) from my iphone to launch camera. I found a tutorial to do that from my ipad or iphone but the phone have to be connected to the ezb by wifi. Is it possible to do that without using the wifi and use directly the box to access to the ezb. Is it clear? If it s possible, does it exist a tutorial? Christophe
OK David and thank you very much
i found your discussions https://synthiam.com/Community/Questions/6499&page=3
With all the informations, i going to find a way but thank you a lot for your help. If i found a solution i will describe the way to found MAC address.
Until now, I just have the SSID of the EZ-B V4 Christophe
Well By using the router of my box "freebox" i found the mac adress the IP address given by my box. I can confirm the suitable ip adress by insert it in the bowser. In client mode with the ip adress, i get the folowwing page.
But when i try to use the IP finder of ARC to detect th IP, it doesn't find it and it s the same history when i try to scan the ip from the app mobile of my iPhone.
I think i'm going to let it down because i really don't know to do.
it's seems to be like if the ip adress was well set but no application could catch it. .... confused confused sick stress
i'm going to do a last thing. Is to define ip fixe in my routeur with the mac address....
Christophe
In the connect box in ARC, you can just specify the IP address instead of use the scan tool with a :23 at the end.
If this doesn't work (which it should) then it looks like something in the firewall settings of the router is blocking port 23 from communicating on your network. Since everything would be inside the firewall, it would look like the router has a bad configuration or a configuration that is blocking things from communicating internally. It might also be a firewall on the phone I suppose, but I doubt it since you can connect in AP mode to the EZ-B from the phone.
** EDIT ** Is your phone connected to your wifi network? You could try to connect to the EZ-B from your computer to see if the issue is on the network or not.
David when i come back in mode AP with my ihone in mode wifi. there is no probleme. i can access to the APP mobile. My network seems to works fine. am i alone in this cas ? Christophe ?
#15
So, from a PC, can you connect to the EZ-B in Client mode?
