Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Germany
Control UBTech Alpha Servos With The Ez-b V4?
Control Ubtech Alpha Servos With The Ez-B V4?
Hello, I have a question .
I have these servos in my robot and have now bought the EZ-B V4.
But if it does not get to work, can the Ez b control these servos?
The servos are all connected and the controller only has 1 cable
greetings
Can you post more details:
Servo brand and model ?
or
Product/Kit details ?
Germany
Hey, thanks for your answer.
It is the Ubtech Alpha s1
Data of the servo:
UBTECH Alpha 1S Robot Parts Digital servo UBT-12HC
description:
Model UBT-12HC Communications: Serial communication Speed: 6.5V: 0.238sec / 60 degrees 8.5V: 0.198sec / 60 degrees Torque: 6.5V: 8kg.cm 8.5V: 12kg.cm Gear: Copper alloy gear Bearing: Ball Bearings Angle range: 0-180 degrees, Adjustable Dimensions (mm): 44 * 22.5 * 29 Weight (g): 42 Amount of operating voltage (V): 7.4V Stable Current: 2.5A Operating temperature range: 0-55 ? Protection: Over Voltage, Over Current Dead bandwidth (no reaction zone): 0 Feedback: Position / angle feedback
If there's a data sheet for the serial communication protocol, then it would be an easy implementation as a plugin. Post the datasheet and I'll take a look.
I can't find the datasheet that contains communication protocol. Can anyone else find it? Maybe ubtech customer support has it
There is no contact to get with ubtech.there is not even a forum.
Germany
Can not find anything to unfortunately:( That's a shame I was so happy to test my ezb.
Germany
Is it possible to read the datasheet of the servo via the Ubtech Pc software?
not with the standard program from alpha1 and 2 this is the only link i can google.
ubtech
