Rplidar icon Rplidar — Slamtec Lidar driver for ARC; scans 360° and publishes distance data to NMS for mapping, obstacle avoidance, and navigation. Try it →
Controlling 2 RGB Leds With EZ-B V4 & ARC Software
Can the EZ-B V4 controller and ARC software control 2 RGB Leds ( 5mm, common cathode, 20ma) simultaneously to provide different colors on demand? Thank you for your help.
EZ-B V4 Info by Synthiam
Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control.
Use the 3 PWM Sliders for each 3 I/O ports per led. You can adjust the r g and b values with that. Then, you can script the color animations later once you get it working.
